2003-2005 Jeep Liberty Air Filter Mahle Jeep Air Filter LX 2942
main picture
We compared price of 2003-2005 Jeep Liberty Air Filter Mahle Jeep Air Filter LX 2942 across hundreds of online stores. We found 2003-2005 Jeep Liberty Air Filter Mahle Jeep Air Filter LX 2942 in 1 store with lowest price $12.24 in AutoPartsWarehouse. For detailed price comparison of 2003-2005 Jeep Liberty Air Filter Mahle Jeep Air Filter LX 2942 check table below.
Merchant Price -
AutoPartsWarehouse [show price]
2003-2005 Jeep Liberty Air Filter Mahle Jeep Air Filter LX 2942 description from AutoPartsWarehouse
Mahle Air FilterNotes: PrimaryWith MAHLE air filters, up to 99.9 percent of dust, soot and tire wear particles are filtered out. At the same time, an optimal air/fuel mixture is assured. The high particle uptake capacity ensures long service life under extreme conditions such as heat, cold or chemical contaminants. MAHLE quality air filters prevent premature wear of valves, cylinder working surfaces, piston rings, bearings and other engine components.
Customer review
I was looking for a stylish air filters for my mom. So I came across this 2003-2005 Jeep Liberty Air Filter Mahle Jeep Air Filter LX 2942, its very cheap and looks good . Once I received it I pulled it out to look at it and it is so gorgeous and sparkles.
