2004 Isuzu Rodeo Fuel Injector Standard Isuzu Fuel Injector FJ1011
main picture
We compared price of 2004 Isuzu Rodeo Fuel Injector Standard Isuzu Fuel Injector FJ1011 across hundreds of online stores. We found 2004 Isuzu Rodeo Fuel Injector Standard Isuzu Fuel Injector FJ1011 in 1 store with lowest price $150.61 in AutoPartsWarehouse. For detailed price comparison of 2004 Isuzu Rodeo Fuel Injector Standard Isuzu Fuel Injector FJ1011 check table below.
Merchant Price -
AutoPartsWarehouse [show price]
2004 Isuzu Rodeo Fuel Injector Standard Isuzu Fuel Injector FJ1011 description from AutoPartsWarehouse
Standard OE Replacement Fuel Injector (New) The Standard Fuel Injector is ensured to provide absolute quality, function, and design that perfectly replaces the rusty and old stock. It has advanced flow which promotes smooth engine operation, provides equal fuel delivery, and can withstand extreme heat conditions.Features and Benefits:Advanced flow matched injectors promote smooth engine operation and equal fuel deliveryCan withstand extreme heat conditionsMade to have great design that fixes inherent failure issues
Customer review
I am very respectable with my buy, this commodity are of excellent quality and good ready-made . Very thanks.
